Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Pool pump/filter recommend please
    Dec 2005
    Default Pool pump/filter recommend please
    I need a new pump/filter for my pool.
    25000 gallon vinyl liner in-ground in the So. Cal. Desert. Current pump is a worn out 1.5 HP with a worn out 48 sq ft DE filter.
    THe electric company gives a $250 rebate for a two speed pump ($30 for a single speed). So, two speed is the way to go.
    Line to to/from pump are 1.5 inch.
    I propose a 1.5HP uprated two speed pump and a 48 sq ft DE as replacements.
    What say the experts?
    Dec 2005
    Default
    So, no comments?
    Default
    I am interested also, as I am going to purchase a new pump in the next couple days. Maybe we can get a few folks to mention their preferences and why. Thanks.
    duraleigh Guest
    Default
    Hi, Mike/Scott,
    When I built my pool, the consensus was to pump enough water to turn over your pool 2-3 times a day. (on high speed) (30,000 gal pool needs a pump to turn approx 75,000 gal in a 24 hour period......52 gal per minute.)
    Then, choose a filter that is rated (in gpm) of at least 110% and maybe 130% of that 52 gpm....say, around 60-80gpm.
    The trick will be in calculating total head of your pool so you can look up the curve of a particular pump and see if it satisfies your requirements.
    I seem to remember an average pool has a total head of about 50 but I think there are others on this forum who have better info on that.
    My pump and total head computed out to about 90gpm on the curve (1.5 full-rated) so I got a filter rated @ 140 gpm.
    To summarize, compute how much water you need to turn, get an average idea of your total head, find a pump curve that matches that, get a bigger filter.......you're good to go.
    Dave S.
    Dec 2005
    Default
    Quote Originally Posted by duraleigh
    Hi, Mike/Scott,
    Dave S.
    I've kinda done that. The hard part is coming up with total dynamic head. SInce the pool exists, I cannot go out and figure out how many elbows and such are there. I don't have X-Ray vision. So, I went with the typical 40 to 50 feet of head. A 1 hp full rated or a 1.5 hp up-rated pump fits the bill, at least it does if I haven't screwed up something. Also, a 48 sq ft DE filter has about 1.5 times the needed flow rate, so I think thats the correct choice.
    I'm looking at a Hayward Super II pump or a Pentair Whisper flow. The exact model depends on whats on Southern California Edison's rebate list.
    I'm looking at a Pentair FNS plus or a hayward pro-grid.
    I think I'll also put in a rainbow in-line or off-line clorinator (model 300 or 320).
    mas985's Avatar
    Pleasanton, CA
    Default
    The most accurate way to determine head is to measure it.
    What is your filter PSI? Multiply it by 2.31 to get return head.
    Suction head you can get with a vacuum gage (Sears has them for $20). Multiply in mg by 1.13 to get suction head, then add together. Once you have total head you must scale it by GPM of the new pump. Unfortunately, it is an iterative process because GPM and head are dependent upon each other. I use a spreadsheet with hydraulics equations to solve for each.
    For comparison, I have a 21,000 Gallon pool with 2.5" & 2" plumbing, filter, heater, spa and 1HP Northstar pump. From measurements that I took, my head is about 56' @ 92 GPM.
    Also, if I had a bit more information, I could estimate head for you and what it would be with a different pump.
    Current Filter PSI
    Equipment list
    # Suction lines, ~ length & dia
    # Return lines, ~ length & dia
    The rest I can guess.
    Dec 2005
    Default
    Well, current filter psi is a bit of a problem. When I took everything out of service for the winter, "normal" filter psi after backwashing was about 4 psi. The problem is that I get crap for flow. The filter is a 48 sq ft stainless steel nautilus with pin-hole leaks and a leaky seal. The pump is a old bronze 1.5 hp aqua-flow, which I understand eats impellers. The system is shot, so any pressure reading I get is probably bogus. I can never get the filter psi over about 8.
    When I bought the house, the pressure guage didn't work (I plumbed in an automotive pressure gauge just to get enough sensitivity to see if the system worked). The pump had no strainer basket and the pool skimmer had no basket. I took apart the filter and it was completely full of very brown DE. I replaced one grid, patched two more grids and several grids had internal stiffeners cracked and broken and I just left them. I only had two months of usable season left and knew I would replace things in the off season.
    The suction line I would estimate at 36 + 18 + 10 feet or 74 feet. Its a 18 x 36 pool and the equipment is maybe 10 feet off the corner furthest from the skimmer. The return I would estimate at 10 feet as its a straight shot to the pool corner. All piping is 1.5" except between the pump and the filter, which is 2". Equipment would be a 48 sq ft DE filter a 1.0 full rated or 1.5 up rated pump and a in-line clorinator, unless something else looks like better match. The pump is intended to be two speed.
    If you can provide some rational numbers, I would appreciate it. I plan to go down to leslies pools and order some stuff tomorrow morning. They are having a 20% off sale, so they are very competitive with an internet purchase. Right now we are looking at the hayward products, the 1.5 hp super II pump and the 48 sq ft FNS filter. I'm also considering pentair products, but leslie has less of a selection of that brand for sale.
    mas985's Avatar
    Pleasanton, CA
    Default
    If you only have 1 skimmer and 1 return line, your head will be quite high with a full rate 1 HP pump. I estimate over 70 ft of head which is mainly due to the 1.5" 75 ft of suction pipe.
    The maximum recommended GPM for 1.5" pipe is about 42 GPM. If you go with a 3/4 HP, the head will drop to 60' @ 57 GPM. At 1/2 HP, the head will drop to 47' @ 50 GPM. These are only approximate since it depends on the pump type.
    Here is a web site to help with pump sizing:
    http://www.poolplaza.com/pool-pump-sizing-2.shtml
    Dec 2005
    Default
    Basically your telling me that its about impossible to optimize my pool. If I go with a 3/4 hp pump, then I'm slightly overdriving my plumbing. I might be able to live with that, but then, on low speed, I'm basically moving not enough water to turn over my pool. Low speed is 3/32nd hp. Not much flow and thats a lot of water to move. I think I can get maybe 20 GPM or so at low speed, but since TDH goes down with the lower velocity, I have not idea what it is.
    To turn over a 25000 gallon pool in 8 hours requires 52 GPM. Since I can only get 44 GPM out of 1 1/2 inch pipe, this is impossible.
    Aparrently the 44 GPM comes from the building code requirement to not exceed 8 ft/sec in the pipe. A pipe can technically support the flow, but pipe damage can occur. Thus, I can exceed 44 GPM and the pump shouldn't cavitate or do evil things.
    A better match is the 1/2 hp pump, but then I'd get essentially nothing out of low speed, if I can find a two speed pump.
    The most correct answer is to add a second suction and return or convert to 2" pipe, both which are essentially impossible on an existing pool. I actually have a second return. That is intended for a pool cleaner with a booster pump. Since the pressure side head isn't a large contributor compared to the suction side, I don't think it would help much.
    duraleigh Guest
    Default
    Hi, Mike,
    Mas985 has given you some great info but you seemed to shuffle it aside maybe a little too quickly. Two thoughts come to my mind....Could you get your .75 2-speed pump (for the rebate) and run it on high all the time? Seems simple enough.
    When you get your new pump and filter, could you replumb your booster pump line to become a suction line...or perhaps perform both functions if you use the booster pump.
    I will also promise you can push more than 44gpm thru a 1.5"pipe without harm....been there, done that.
    Impossible to optimize your pool? Optomize means doing the best you can....not perfection, but the best you can do with what you've got. I think you can improve your system markedly with a little more planning.
    Dave S.
  1. -- CLOSED THREAD/ PoolDoc -- recommend auto cleaner for 18' Intex Ultra w/ 1hp pump
    By Psychoknight in forum Intex-type Pool Setup & Operations
    Last Post: 04-19-2012, 08:45 AM
  2. Pool covers - what do recommend
    By Philip in forum Pool Equipment & Operations
    Last Post: 03-10-2012, 12:11 PM
  3. can someone recommend a quality heat pump??
    By blondie_30 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-08-2008, 12:27 PM
  4. Please recommend an Automated Pool Cleaner
    By vlad7 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-10-2006, 11:43 AM
  5. Recommend a filter
    By jlakers in forum Pool Equipment & Operations
    Last Post: 04-12-2006, 08:32 AM
