Results 1 to 8 of 8
Thread: Pool Pump Capacitor?
    May 2010
    Default Re: Pool Pump Capacitor?
    Electric pumps and motors are not my area of expertise, but If I understand capacitors correctly, they are used to jump start the motor from a stop, because it take a bigger jolt of electricity to start a motor, especially with a load on it. Once the motor is running, it settles down and runs on a lower amperage. Sooooo, If your motor starts, I'm not sure you have a bad capacitor. My very limited experience says capacitors either work or they don't. I have seen (heard) motor capacitors hum very loud, but they won't start the motor.
    Does your motor "Drag" and take a few extra seconds to finally come up to speed, or does it start right up?
    Hope this helps. BTG
    mas985's Avatar
    Pleasanton, CA
    The capacitor in an induction motor is used to shift the starter winding current by 90 degrees so the motor will spin up from a dead stop. Without a capacitor or if it is bad, the motor will just sit there and hum. To replace it, you can remove the back cover but I wouldn't suggest doing this unless you are familiar with working on motors and electricity.
    Mark
