Re: Conversion Complete, but pool still cloudy!
I have been sweeping daily to keep junk stirred up. Skimmer socks have been catching ALOT of brown stuff(mustard algae??). So, I bought 2 qrts of polyquat yesterday, and put it all in there last night. I know, it was too much
, but my mind wasn't working, & I was desperate.
This morning, I CAN SEE THE BOTTOM SEAMS IN SHALLOW END!!!!!
YEA!!!! There is a slight oily looking film on top of water. I have one of those floating sponge things, I hope it will take care of that.
The skimmer socks were completely brown, so I cleaned them & then backwashed. OH MY GOODNESS!!! The water was horrible!!
I added 3 gallons of bleach this a.m. & 9 ounces of clarifier.
Sound ok??
I looked at the Pooltrine brand Polyquat and they recommend 16 oz per 10K gallons so for your 30K pool you would use 1.5 quarts so 2 quarts isn't way off.
As far as the chlorine, what do your latest test numbers look like?
Lastly, I don't know how well a clarifier works so I can't help you there.
If you look up mwsmith2, try to send him a PM - since he has dealt with mustard algae he should be able to give you good advice.
Peter
Instead of brushing the stuff and just stirring it around, vac it to waste. There is no sense in leaving it in there, especially if the chlorine is still fighting it. I had small amounts of that brown residue when I did my conversion last year. The key is keeping the bleach hammered to it 3x a day to your proper shock level. If your CYA is 100, then you need to be adding more bleach than you are now, like mentioned above. Are you usine the bleach calc? If not, it is a must have, so download it. Don't give up, you will actually enjoy your pool this year instead of fight algae like I did all last year.
Good Luck!
Guess What!!!!!
I HAVE A BOTTOM DRAIN!!!!!
IT'S FINALLY CLEAR!!!!
I had forgotten that I have a drain down there. It is a tiny bit cloudy, but hey, I'll take it!!!
I DID IT!!! Thank Y'all SOOO much!!
Added 9 oz of clarifier & presto!! Pool is perfect!!
