Results 1 to 10 of 21
Thread: Hi please tell me how long to backwash ?
    Default Hi please tell me how long to backwash ?
    How long do I backwash ?
    Mandeville, LA, USA.
    Default Re: Hi please tell me how long to backwash ?
    Do you have a sight glass on the bachwash line (bubble looking thing)? If so, backwash until the water in the sight glass is clear. If not, backwash for about 2 minutes, go back to filter mode, check your pressure to see if it has returned to the "clean" level, and repeat as necessary (though 2 minutes of backwashing will usually suffice).
    Make sure that you shut down the pump each time before moving the handle on the multiport valve.
    Saint Cloud, FL
    Sierrasmom,
    We need to know some details of your pool setup, ie. pool size, pump size, filter, solar panels if any to answer that question.
    Pat
    27 round above ground pool 1.5 for the pump jacuzzi sand filter
    Hi Sierrasmom,
    it really doesn't matter how big/small or indifferent your pool is, whether your filter is black green red or blue, you backwash until your water coming out is clean/clear. Like Kurt mentioned, if you have a sight glass, it will tell you when to stop by the color (or lkack thereof)of the water, after stopping the pump, switch to rinse for about 10-20 seconds to clear out any debris still floating in the top of the filter.
    If you do not have a sightglass, look at what's coming out the end of the hose - same deal there.
    If your filter was extremely dirty, it may take 2 minutes or more to get it clean, if it was just somewhat dirty, a minute may do the job - see how pool size doesn't come into effect.
    ok thanks but someone asked how big my pool was and pump was .sorry i asked a question from now on i will just read and not ask ..i just need some questions answered we bought this pool from an individual it didnt come with anything i am just trying to get it clear so my daughter can enjoy it this summer ..
    Green Bay, WI
    My routine is switch to backwash, watch the sight glass and watch for clear water, usually about a minute, then rinse, then back to filter, shutting off the pump between any filter position changes.
    I have never really thought of this before but should you typically backwash in high speed on a two speed pump, would it matter, just take more time on low speed? I have always backwashed in high speed.
