I have a question regarding a leak in a gunite pool. I have a 15 X 40 gunite pool that is losing right at an inch a day. The water level stops dropping right at the bottom of the lowest skimmer mouth. The skimmer bucket is still holding water all the way up to the level of the skimmer mouth. My question is with there still being water in the skimmer bucket, does that rule out a plumbing line leak? I would think if there was a leak in the line that all the water would drain out. I also don't have an equalization line. I looked around the skimmer and found no visible cracks and I shot some dye around the mouth and the skimmer bucket and could not tell much because the water is cloudy(can't run the pump because of the water level.) I also checked around the entire pool at the level where the water stops dropping and found no cracks. I had a pool guy come by and take a look and he said he wanted to first pressure test the skimmers and epoxy the pool lights. It did not quite make since because I would think if the lights were leaking the water line would drop to the level of the lights and if it was a leak in the skimmer line then the skimmer bucket would be empty. Just dont want to spend a ton of money for him to tell me that is not where the leak is when common sense is kinda telling me that already. Again all this is with the pump off. Any help would be appreciated.
