Hi, Michelle, and welcome to the Pool Forum!
Scoop out as much debris (leaves, frogs, salamanders and anything else) as you can with a net. Order a good test kit now so you can get it quickly. You'll need it to help you clean this mess up! The one we recommend is the Taylor K-2006 or 2006C which is the same kit with larger quantities of reagents. You can order it through the Amazon.com link in my signature below.
In the meantime, pick up a cheap OTO kit somewhere. I don't know if stores like Walmart are stocking these yet this early in the spring. If not, you'll have to pick one up at a pool store. Actually, while you are at a pool store, it wouldn't hurt to go ahead and let them test your water but just don't let them talk you into buying anything at this point! They will try! Come back here and post your numbers and somebody here will help you go from there. (Make sure that CYA is one of the things they test for you.)
Is your equipment hooked up yet? If not, go ahead and hook it up and start running the pump and filter so the filter can help you clear it. You'll have to watch the pressure on your filter and when the filter pressure rises 8-10 psi over clean filter pressure, it is time to backwash your sand filter.
What did you use to chlorinate with in past years? Do you have any idea what your CYA (stabilizer) level was when you closed in the fall?
We'll help you get it cleared up!
