Results 1 to 10 of 22
Thread: Please Help!!!! Swamp pool
    Mar 2012
    Default Re: Please Help!!!! Swamp pool
    Ok thanks. I am getting the test kit and I have to replace a part on my pump then I can cut it on. I will reply back with the test results and we can go from there. Thanks so much for your help!
    You're welcome.
    Mar 2012
    Default
    By watermom told me to get water test. Results r free chlorine - 0 ppm. I knew that's was gonna be like that cause o have not ran my pool since last year. pH - 7.6. Alkalinity -100 ppm. Calcium hardness 160 ppm. Cyanuric acid- 25 ppm. The multi- value I ordered should be in this week then I can cut the pool on. Now were do I go from here? Thanks!!!
    I did also go to Sam' s Club and got chlorine tablets, chlorine granules, baking soda and shock packets.
    BigDave's Avatar
    List the chemical ingredients of the chlorine tablets, chlorine granules, baking soda and shock packets for better advice.
    I can tell you what she's got -- if it's "PoolBrand". The granules are straight dichlor (50#), as are the shock packets. The tablets are 3" trichlor (40#, I think), and the baking soda . . . is baking soda
    Given that she's got a swamp, it's probably not too much. She will need a K2006, to be able to gauge what's going on.
    Jun 2011
    In the Sticks near Houston, TX
    As someone who has done this several times, why not just dump and refill?
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    She has an in-ground vinyl pool -- dumping and refilling without professional help will almost certainly destroy the liner.
    Draining an AG pool is usually not a big deal. Draining an IG *gunite* pool is not a big deal UNLESS the ground is very wet. Draining a vinyl pool is hard to do correctly, and requires a high suction / high volume air blower.
    Mar 2012
    Default
    Ok PoolDoc is right. I do have poolbrand. I don't know what (50#) or (40#) mean but the active ingredient in the granules is : Sodium Dichloro 99% and the 3" chlorine tablets : Trichloro: 99%. I have ordered that K2006 test kit but have not received it yet. The shock has both sodium Dichloro -s-99% Triazinetrione hydrate: 99%. And baking soda is plain baking soda. Oh the available chlorine in the granules is 55.5%. The available chlorine in the 3"chlorine tablets is 90%.I have replaced the parts now I am ready to go!
    Also after reading other post last year I thought I had some something wrong and my liner got stained. I believe I have to much metal in my water how do I test and treat for this? Will that K2006 test kit but do that?
    40,000 gallon (?) in-ground vinyl liner pool with sand filter.
    Mar 2012
    Default
    @The Goose: cause my pool holds 40, 000 gallons of water and it will cost me around $700.00 to refill! I wish I could do it that way!
    Ok dim.of my pool is 16×30. Make and model Hayward S200. I have a chlorine feeder that I put my tablets in. I would like to start using my pool when ready. I have replaced everything needed on pump now working correctly. The stains are around the top part of my liner. It is a dark brown color. Last year I did add an algaecide. I also have the K2006 test kit. So were do I go from here?
