By watermom told me to get water test. Results r free chlorine - 0 ppm. I knew that's was gonna be like that cause o have not ran my pool since last year. pH - 7.6. Alkalinity -100 ppm. Calcium hardness 160 ppm. Cyanuric acid- 25 ppm. The multi- value I ordered should be in this week then I can cut the pool on. Now were do I go from here? Thanks!!!
I did also go to Sam' s Club and got chlorine tablets, chlorine granules, baking soda and shock packets.
Reason: merge posts
