Re: Gunite pool leak help
Well I put epoxy all around the skimmer where it meets the concrete and it still leaks. I did it to both skimmers. I talked to the pool guy again and he said that if a light was leaking it could stop the water line at the skimmer. That doesn't make sense to me because I would think it would leak all the way down to the light. He said something about it could be leaking down to the water table and stabilizing. Could someone explain? I am filling it up everyday and it leaks at the same rate until it gets to the bottom of he skimmer mouth. Thanks
IG gunite 15'x40' swimming pool
