Results 1 to 10 of 10
Thread: New Clorox Formula?
    Apr 2011
    Default New Clorox Formula?
    Hello Everyone! I see Clorox has changed their formula to a concentrated version. Will this work the same as the original formula?
    Cooper
    Default Re: New Clorox Formula?
    Yes, just scale down the amount needed since it's now 8.25% concentration instead of 6%.
    Ok...so, the simple rule of thumb is....
    1 gallon of 8.25% will add 8.25ppm of FC to 10,000 gallons, or 4.125ppm of FC to 20,000 gallons or 16.5ppm of FC to 5,000 gallons.
    Virginia
    Perfect timing. I just bought some to prepare for opening next week and was wondering about that.
    Thanks.
    "Carnack the Magnificent, knows all, sees all!"
    Virginia
    Lol....that was a blast from the past.
    Jun 2011
    Northern VA
    I have been struggling with this today myself. The higher concentration of chlorine isn't the problem for me, it is the size of the bottle - they are 3.78 quarts or 121 ounces. Close to a gallon but not...
    27 ft x 52 in AGP
    Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
    27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
    OK, the actual formula is:
    (1,000,000/pool volume) * concentration * amount = FC added.
    Volume is in gallons
    Concentration is as a decimal, so it's .0825
    Amount is in gallons as well so 121 ounces is .945 gallons.
    So your calculation is: (1,000,000/17,200) * .0825 * .945 = 4.533, or 4.5 is the FC added to your pool from 121 ounces of 8.25%
    The rule of thumb makes this easier but this is the formula it comes from. BTW, FYI: as long as your units in pool volume and amount are the same (gallons vs gallons, liters vs liters, ounces vs ounces (!) ) the formula works.
    Virginia
    This calculator is also helpful:
    http://www.poolcalculator.com/
    Jun 2011
    Northern VA
    Thank You CarlD!
    27 ft x 52 in AGP
