Results 1 to 10 of 12
Thread: Pool pH is at the "ideal" level, but alkalinity is super high
    Default Re: Pool pH is at the "ideal" level, but alkalinity is super high
    Hi Mind!
    You can use the pH Up! in your laundry (if it's Sodium Carbonate) as a nice booster.
    Alkalinity Up! is baking soda. You could use it to keep your fridge sweet-smelling.
    pH Minus can be replaced by either Muriatic Acid, available at hardware stores. Muriatic is the best way to lower pH but you do have to be very careful using it--wear goggles and gloves, pour it into a 5 gal bucket of water before adding it to the pool.
    But pH Minus is what is generically called "Dry Acid" and is sold as that, much cheaper. Also easier to handle than Muriatic Acid.
    What needs to be stated explicitly: Generally, if your chlorine level is good and your pH level is good, your pool is safe to swim in.
    Mar 2012
    Boerne (San Antonio area), TX
    Thank you both for all the info Definitely took away a lot of my headaches
    We jumped in it yesterday... cold as all get out but it was worth it to say it was ready!
    Edit: And looking forward to better tips on how to properly take care of it with less/easier/cheaper chemicals!
    Intex #54451 Ultra-Frame - 5061 gallons
  1. Ph is ideal, alkalinity is a little high
    By Mftek1 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-15-2013, 05:54 PM
  2. Can I use "Pool First Aid" when chlorine is too high?
    By busymomma in forum --cleanup--
    Last Post: 06-09-2013, 09:16 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
