Results 1 to 10 of 10
Thread: Hose bib connection on Waste line?
    Default Hose bib connection on Waste line?
    How would I go about connecting a hose bib on a 1 & 1/2 " waste connection?
    Ft Lauderdale, Fl
    Default Re: Hose bib connection on Waste line?
    Well, a reducer bushing with the appropriate thread would do but you have to be careful as reducing the pipe down to a 1/2" or 3/4" hose bibb will be very restrictive on your pump and filter.
    Sean Assam
    Green Bay, WI
    At most local home improvement stores you should find the parts necessary. Although like Sean noted 1.5 inch to 3/4 is about a 4 times reduction in flow rate, not to mention hose bibs often start at 1/2 inch or smaller at the valve. If your going to try it once you get to 3/4 or so add a "T" and put two hose bibs on it, that way you can at least run out 2 3/4 inch hoses, about 1/2 the flow of a 1.5 inch.
    What are you trying to do? Maybe we can help beyond what was said above if we know the purpose.
    I did find a brass hose bib with a ball valve at home depot that we use on the backwash for our pond filter. Much less restrictive. This allows us to hook up a hose and water plants when backwashing. This is on a small submersible pump that only moves about 1/4 the volume as the pool pump though.
    Quote Originally Posted by dep78737
    I am trying to figure out how I will backwash and drain if I buy a new filter (don't even ask me about the ancient DE filter that I "inherited" with this house and pool). I am thinking of a Hayward top-mount sand filter, or a cartridge model. There is no septic drain anywhere near the pump and filter, so I will have to use a hose somehow to backwash. I could not find any PVC parts at Lowe's or Home Depot that would adapt 1 1/2" down to 3/4" (which is the size of my garden hose, I believe).
    Thanks for whatever advice that you can give.
    Mandeville, LA, USA.
    Most people either hard pipe the bachwash outlet into a drainage tile or into the sewer or use a roll-up 1.5" backwash hose (you can buy them at HD, Lowes, Pool Stores, Wal-Mart, etc.) just rolled out onto the lawn.
