Re: Hose bib connection on Waste line?
In post #5 you kind of imply you want to dump the waste into a septic system? You really don't want to do that simply because the quantity of water is not desireable. If you mean a municipal septic, that still doesn't make sense unless there is some 'STUPID' code that says you can't dump to a storm sewer or even on your lawn. As a modification of MarkC's comment about the rolled up waste hose you could even punch holes in it and seal the end to distribute the dump over whatever length you want.
