Raising Chlorine Making Water Green
Been using BBB method for a few months successfully. Tree debris and pollen began to fall and I let chlorine level drop too low. There was no algae at that time. I noticed when I checked Cl level - DPD FAS method -Taylor 2006. I put 4.25 gal of bleach in - pool is 25k-26k gallons. The next day Cl was 0 and water was real green, with small white spots on surface of water, and some foaming in skimmer, but no algae on sides or steps that I could see. Did nothing else for 4-5 days while looking for information on this site. Thought maybe I may have to much chlorine and it wasn't registering. I then read in forum that is unlikely with DPD FAS method. Pump has been running 24/7 f0r last 3 weeks to keep pool clean. Green color actually improved with chlorine at 0, but this weekend a small amount of algae began to appear. I decided to continue to add chlorine to raise level to at least 10ppm. Numbers when I began on Friday 3/31/12: Cl - 0, PH- 7.6, Alkalinity-110, Calcium Hardness-80, Cyanuric-55. Began Saturday with 1.5 gal bleach at 1pm and Cl went to 1ppm. Added another 1.5 gal at 145pm, in 30 min Cl was at 3.5ppm. Checked Cl at 930pm and Cl was 2.5, so I added close to 3 more gal of bleach. Checked Cl this morning and was at 4.5. Green color gets worse as I add chlorine, and some foaming in skimmer. PH, Alkalinity have not moved. Added another 1.5 gal of bleach today after brushing and backwashing Hayward sand filter. I am now at 4.0PPM Cl. Do I coninue to add large amounts of bleach even though it seems to make green color worse? How much can I add at one time? Sorry so long, but wanted all information included.
Pool information: 18x36 vinyl pool; Super Pump, Hayward Sand Filter, Heater(valved off), county water system
In-ground rectangle 18x36 vinyl, 26,000 gallons, Hayward super pump, 1/2 HP motor, Hayward Sand Filter, Hayward Navigator Cleaner, Gas Heater (valved off now), county water system same as house, Atlanta, Ga area
