Results 1 to 10 of 48
Thread: Light green water
    Mar 2012
    Iowa
    Default Re: Light green water
    Thank you. I originally tested with strips but then tested with a test kit once I got it yesterday. Yes we have well water and I know we have iron in the water from old iron pipes. We have had a pool for like 5 years and I have fought with iron every time I shocked it. Last year After much research I took other pool owners advice and manually filtered the metals out by heavily oxidizing and taking a week to filter them out. Then I didn't have iron problems the rest f the summer. However, this was the first year we left the pool with water in it for the winter because we had a bigger pool to hard to take down. I think that I realized what is going on. I don't think it's algae because my chlorine holds for a few days. Plus when I reach down and touch the walls there's no slimy feeling. I don't see anything stck on bottom or sides anywhere. I think the bottom, which is blue is stained with yellow from the iron, thus making it appear my water is
    Ight green. I'm going to bring my PH and alkalinity down. Once I get the water balanced can I use a small amount of iron out through my skimmer to circulate through the pool? That would help me get the stains off of pump, hoses, and liner. Will that add phosphates or anything unwanted to the water?
    Hi Huskerdee --
    1. Do bring your pH down, and keep it NEAR, but not BELOW the lowest reading on your kit or tester.
    2. Do NOT worry about alkalinity or "balance" at this time (and maybe not, ever!)
    3. Do run your pump and filter 24/7, and clean them often.
    4. Do NOT use Iron Out (I'm going to merge your other post here).
    5. Do see if you can find some HEDP based stain control agent: Jacks Magic Blue, Pink or Purple stuff are ALL HEDP, though I don't know what the concentrations are. I do know the "Pink Stuff" is the most concentrated. (Did a little more checking: it looks like the Pink Stuff is full undiluted 60% HEDP -- so that's 3x as concentrated as the Kem-Tek product. It's available on Amazon, but not with free shipping.)
    This product:
    Kem Tek Calcium and Metal Eliminator
    is available at Amazon for $14 with free shipping if you get 2. It's 20% HEDP, so that's a good price, and it will keep indefinitely. (But store the bottle out of the sun -- the plastic will break if you don't!)
    Once you've gotten your pH down, and have added the HEDP, let's see what happens. We can look at other options, once you've gotten that far. By the way, do NOT use the HEDP on the "if a little is good, more is better" basis -- follow the label!
    Mar 2012
    Iowa
    Thank you. I have my PH down to 7.4, do I want to keep going with the acid? I will order the Stuff you told me to and let you know what happens. Again, thank you.
    Go to just above whatever the lowest reading on your pH test is.
    You have to remember, that if 7.0 is the lowest reading on your kit, a reading of 7.0 does NOT mean that your pH is 7.0. It means that it is 7.0 . . . OR BELOW! It could be 6.8, which wouldn't hurt anything in your case. But it could mean 5.8, which would damage your liner fairly quickly!
    Mar 2012
    Iowa
    Default Ok
    The lowest on mine is 6.8 so I will get it to 7.0. I ordered the 2 bottles of that metal calcium stuff. It says it'll be here by the 29th or 31st. So I want to leave the pump running 24/7 until then. I know I need to scrub and vacuum daily also, which I do. Do I want to add any clarifies or flocs? Or just keep filtering? I appreciate your help so much. I have learned a lot from reading posts in the forums and am learning more now
    Intex 16'x32'x52" model #54985 with ~14,500 gallons, filled with iron contaminated well water.
    Mar 2012
    Iowa
    Default Re: Ok
    Thank you, no floc or clarifier!
    Mar 2012
    Iowa
    Default Re: Ok
    I had the PH down to 7 but it keeps creeping back up. How can I keep it down w/o using acid daily? I am suppose to have the metal chemical tomorrow and will add that. That won't help stabilize my PH though, will it? My chlorine holds steady and I have had to add bleach as it' really high.
