I have a 20 X 40 IG vinyl pool with a Hayward SP-580 Series Astrolite Underwater Light Fixture. How do I go about changing the bulb - and where do I get one. If I read the drawing correctly I am assuming that I get in the pool and take the faceplate off. I then assume I need to disconnect the wiring that is about 10' from the pool and tie a snake to it, then go back in the pool and pull the entire assembly out, change the bulb in a dry area and then seal the unit and reverse the procedure. Is that correct or is there some other way this gets done?
