We have a large tear above the water line. Any tips on patching it?
If you go to the Inground pool Construction and Repair section of the forum, there is a stickied thread at the top (4th thread down) that gives info that may be helpful. Until your membership is upgraded, you will have to log out first to be able to read it, though.
Hope this helps.
Thank you....it took me a little while to get there but I found it and read it. I am going to try to patch this afternoon. Mine is above the water line and quite large.... Hope it works.
Let us know how it works out.
membership upgraded.
The vinyl pool patch sticky is here: http://www.poolforum.com/pf2/showthread.php?13118 Apparently it matters what sort of patch kit you use; after reviewing a number of old threads, the consensus seems to be Boxer *only*.
PoolDoc / Ben
