Re: Too Much Shock
Thank you for the replies. I went ahead and shocked last evening. I thought the water was a bit cloudy, no algae, and I'd read (not here) that shocking should be done once a week. After posting, THEN reading, I see that's not really the case.
I had purchased a drop type test kit but couldn't read free chlorine (nor could my wife) so maybe there's a difference in kits. I am using strips until I find a good kit.
My pool is a pebble tech with DE filtration and a variable Haywood pump. I also have a solar heater.
Another question: If chlorine tabs have stabilizer does the stabilizer always stay in the pool? It seems that the chlorine levels took most all day to go down today.
Thanks again.
Dan
12,000 gallon Pebble-Tec concrete pool with DE filtration and a variable speed Haywood pump. I also have a solar heater.
