Thread: Timer Recommendation
    Jul 2006
    Minnesota
    Default Timer Recommendation
    Hello,
    This year I am looking to add a timer for my pool pump. What is recommended as a simple on/off timer to add and a good source to get them from?
    thanks,
    mas985's Avatar
    Pleasanton, CA
    Default Re: Timer Recommendation
    Intermatic T104
    If you have a two speed, you will need to get a T106 as well and you can find them in a single unit like the T10604.
    Mark
    May 2011
    Batesville, MS
    I use a regular hot water heater timer. This is only good if you have a place to install it out of the weather.
    18x36 IG Vinyl...Jacuzzi Pumpworks (the bane of my existance), VERY small pool biz - Full time Science and Math teacher!
    Jul 2006
    Minnesota
    Thank you for the input. One item that I did not mention is that I also have a gas heater. Will the same Intermatic T014 switch recommended previously work? Will it just need the following fireman's switch?
    http://www.amazon.com/Intermatic-156...4885677&sr=8-2
    mas985's Avatar
    Pleasanton, CA
    A fireman switch would be a good idea and yes, the heater is in series with the fireman switch and the timer.
    Mark
  1. Filter Recommendation
    By Alexey in forum Pool Equipment & Operations
    Last Post: 06-12-2013, 10:34 AM
  2. Pump recommendation
    By cmcq in forum Pool Equipment & Operations
    Last Post: 07-14-2011, 09:39 PM
  3. Gas Heater Recommendation
    By kevkline in forum Pool Equipment & Operations
    Last Post: 05-10-2008, 03:10 PM
  4. Recommendation(s) on pump, etc.
    By Cal_Newbie in forum Above-Ground Pool Construction & Repair
    Last Post: 10-25-2006, 03:28 PM
  5. Gas Heater Recommendation... please
    By JWB in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 05:22 AM
