Re: Second Thoughts about In-Ground Pool Installation
Hi, and welcome to the forum!
Congratulations on the new pool--once you get a maintenance routine together, you'll be surprised at how easy it is to keep your pool clean.
I can't answer the questions for you about the water features and the equipment, but we do have several other forum members who I'm sure will be by shortly to answer those for you. My question for you is about the "30 days of startup"....are you using chlorine of any kind in the pool right now to keep it from growing algae? Also, what kind of pool is this--gunite, vinyl, fiberglass, etc? Do you have a drop-based test kit? If so, if you'll post a set of results, we can help you determine what you need to to do keep it clean until time for the SWCG. If not, we very highly recommend the K-2006 test kit, which can be found many places online but the best price seems to be through the Amazon link in my sig below--just make sure Amato Industries is the seller, because some of the other companies substitute the K-2005, which is NOT the same kit.
