Hi Tony;
Loud pumps are approaching the end of their life, but are pretty unpredictable: it *might* die next week OR next year! We can help narrow the choices, but we need info to do so.
1. Send photos of your existing pump, filter and especially, piping to [email protected], and I'll post them. Be especially careful to get photos of the pipes where they come out of the ground. If you can, include a note ID'g each pipe.
2. Tell us whether you are on a tight budget, or have some room to maneuver. A new motor & seal, can be less than $200 if you DIY, but a replacement filter matched to a high efficiency variable speed pump can easily reach $2,000.
3. Have you had a pool before? If so, tell us what is most important to you -- crystal clear water, ease of maintenance, etc.
4. Let us know if there are any water discharge restrictions in your location. A sand filter will have to be backwashed several times each season, and will dump 200 - 300 gallons of dirty -- maybe greenish -- water SOMEWHERE, each time. If that's not possible, than you have to rule out sand filters, even though they are the most durable and the lowest maintenance.
5. Let us know if you have any OTHER equipment -- solar heaters, pool heater, spa, fountain, etc -- OR intend to add such things.
