mas985
Your current pump should well exceed 25 GPM. More than likely your current design point is closer to 40 GPM @ 27' of head for typical AG plumbing.
Also, how do you know that the Pentair uses 10% more power and which Pentair are you talking about? Motor ratings don't really give you a realistic view of the actual power usage. Have you measured your Hayward pump's power? For typical AG plumbing, the 3/4 HP Pentair Optimo uses about 830 watts on high speed with a flow rate of about 41 GPM.
