Results 11 to 12 of 12
Thread: Northstar pump motor replacement
    Default Re: Northstar pump motor replacement
    Quote Originally Posted by waste View Post
    My participation here is lower than I'd like, due to a computer hacker and a job I just started which has 'grueling' hours. I'll check in at least on the weekends and will assist you with the motor swap.
    Good to see you back, Ted! Sorry about the computer problems!
    Cool Re: Northstar pump motor replacement
    Masksav - glad you found a cheaper motor. If installing it gives you trouble, let me know and I'll proffer some tips
    Ben- it's always good to be here! It was your e-mail that clued me into the hacker, THANK YOU! I think my system is OK, but there are a couple things going on that I'm not quite satisfied with,
    Mark- when we first started installing the Northstars, ~ 1/5 had to have motor or seal replacements within the FIRST year. I had heard that the model was going to be discontinued owing to the troubles. That's why I said they were a ~ 'lemon'
  1. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 04:56 PM
  2. In-ground cleaning system, pump motor replacement question
    By kluczenk in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-20-2013, 05:46 PM
  3. Wearing of Impeller and Diffuer on Northstar Pump
    By abrenner in forum Pool Equipment & Operations
    Last Post: 04-14-2012, 06:21 PM
  4. Which Replacement Pump Motor???
    By vgg659 in forum Pool Equipment & Operations
    Last Post: 07-07-2009, 05:21 PM
  5. Hayward Northstar pump install: Review
    By pj1016 in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 11:46 PM
