Re: Northstar pump motor replacement
The plumbing is a little on the small side for that size pump but nothing serious and not much you can do about is anyway. Because of the spa, I think you would do best with a two speed motor replacement of the same size and definitely build something to keep the water off the pump motor. The two speed will help save in energy costs and low speed is all your pool should really need.
