Welcome to the Forum!
Please listen to Mark!!
The Northstar is something of a "lemon"However, I've changed out a few dozen motors and will help you with the 'nuts and bolts' of the changeout.
Pick up a new shaft seal assembly (SPX4000SA2), trying to reuse one, no matter it's age is a very BAD idea.
My participation here is lower than I'd like, due to a computer hacker and a job I just started which has 'grueling' hours. I'll check in at least on the weekends and will assist you with the motor swap.![]()
