Results 1 to 10 of 11
Thread: New guy LOST !!!!
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: New guy LOST !!!!
    Doug,
    Welcome! That's what I like, a guy who actually admits he's LOST!!!
    Most pool stores run many more tests than the ones you posted:
    Free chlorine
    Total chlorine
    Combined chlorine
    pH
    Alk
    Calc hardness
    TDS (total dissolved solids)
    CYA
    copper
    iron
    saturation index
    There's more, I just can't remember this late. Not quite sure why they only ran the few tests you noted. If they can't test for them, find another store. Or, better yet, purchase a drops based kit. Most pool stores carry a Taylors kit (~$70-80) or you can order one of Bens. Either way, testing your own pool water is the way to go.
    Are you still thinking of using the pucks? I used pucks for only 1 year, and my CYA >100ppm. Mainly because my inline Hayward chlorinator knob malfunctioned. Seems to be a problem with their product line. Pucks also drive the pH down as they are acidic. The common wisdom is that the CYA level determines the chlorine range required for proper sanitation. So do get that tested soon. Most of the folks here use bleach for chlorination, or SWG/SWC seem to be on the rise also.
    Can't help you with the hardness question. That's important if you have plaster/cement pools or use a heater. Down here in Carolina water temps are in the 70's. No need for heater, or at least that's what spouse keeps saying.
    Keep reading the posts and you'll pick things up. I'm sure others will chime in with guidance and suggestions, too.
    CaryB
    Yeah, test for CYA. I think you chlorine is a little low, but the CYA level dictates the proper chlorine level. Check out Ben's Best Guess table posted by Watermom.
    And congratulations on being strong enough and smart enough to figure out you are lost and that the pool store "Pool Stored" you! I'm not kidding--it takes a strong person to come here and say what you said. You also did it WHILE YOUR POOL IS STILL CLEAN AND HEALTHY! You are ALREADY on the right track!
    We'll cut through the nonsense and help you enjoy your beautiful new pool for years to come. Don't worry about the size. RARELY do people say "I wish I had a smaller pool!", but they ALWAYS say "I wish I had a BIGGER pool!"
    Thanks, Cary and Carl. Unfortunately, I will probably have to stick with the pucks. I'm away from home due to work about 4 consecutive days per week and need something automated while I'm gone. I guess I need to purchase a test kit that covers all the parameters you discussed. How long do these test kits last before the drops go bad? I have a small drops based test kit that I bought 2 years ago when I first ordered the pool. Is it still good? If so, the results differ from the pool store results. It shows NO chlorine (which makes sense since at the point I tested yesterday there was none put into the pool since it was closed last October), and also showed Ph of 7.2 and Alkalinity of 40. I plan on going to a different pool store today and having a complete water test done again and compare. Also, what is "shock" ? Do I use liquid or powder, and what type? What does it do? How do I know when I need to shock the pool? I really appreciate all the help. The only thing I know for certain is that I have a ton more to learn. If you folks don't mind, I'll post the new water test reults here later today. Hopefully the parameters they test for will be more complete. Thanks for the help and the info.
    Doug
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Just inserting my personal experience here. If you're gone up to 4 days at a time and not using the pool, are you covering it at all while you're gone? I keep my pool covered with a solar cover and I only add bleach about once a week when it's not used, sometimes not even that often depending on my readings (I try not to let my level get less than 5 due to my CYA level). Twice a week when we've been swimming it it. If there's not bather load, theoretically the chlorine demand shouldn't be as high.
    As for how much chemical to put in...have you downloaded the BleachCalc? It's a huge life saver. You enter the volume of your pool & it can calculate the rest for you!
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    HI, folks-
    I just returned from another pool store with a full water test. Here's the results:
    Free Chlorine: 0.5
    Total Chlorine: 0.5
    pH: 7.4
    total Alkalinity: 50
    Calcium Hardness: 140
    CYA: 0.0
    I guess the question now is, what do I add, in what order, and how much? Again, the pool is a vinyl liner 44,000 gallon pool. I think I know why the CYA is gone - I had a leak in the solid cover all winter that allowed the water from the pool to seep up onto the cover, after which the automatic cover pump would dump it all overboard. I had to keep refilling my pool all winter. I would guess that all in all I replaced the vast majority of my water this past winter, 12" at a time! Will the use of the 3" pucks bring the CYA up to where it needs to be, or do I need to add some stabilizer now? I'd hate to raise it to normal levels now, only to have the pucks push it over the edge and have to drain the pool later in the year to bring it back down. The water is still only 56 degrees, if that matters. I think I may be at the point now where I'm starting to see a glimmer of knowledge, but it's just enough to be a danger to myself. Sherra, thanks for the info. Where do I go to download this bleach calc formula? As far as the solar cover, I'm gone alot but my wife and two kids are still here when I'm gone, and the kids are in the pool almost every day. My kids and I basically overuled my wife's objections to the pool when we bought it so she has no strong interest in helping me to maintain it. That's why I need the auto chlorinator. The kids are still to young to maintain the pool in my absence. Also, if anyone has answers to my shock questions asked in the post above I'd certainly be appreciative. As I said earlier, I'm still lost, however I feel that slowly I'm starting to learn. Thanks again to all of you for your help so far. I look forward to the time when I know enough that I can return the favor by helping another who is lost as I am now.
    Doug
    Area Man is offline ** No working email address ** Area Man 0
    OK.
    Doug,
    Wait for others to reply, because I'm learning too. But I think you should add an initial dose of CYA rather than relying on the pucks. Michael's BleachCalc calculator suggests 10 lbs or so to get your CYA up in the 30's.
    Did the pool store really report your total alkalinity at 50 today, and 110 yesterday? Something seems wrong there. Using Ben's test kit gives me very consistent TA results.
    It also seems odd that they reported lower calcium hardness today, after you added the "Hardness Plus" they recommended yesterday. My general recommendation is: test it yourself! I value my pool store, but am having better results from my own testing and adjustment using information from this forum.
    Rick
    Rick,
    I agree that I need to get a test kit. The stores around here (I tried the 4 that I know of) all sell the small kits that don't test for CYA. I know Ben sells them, but I think I should get one fairly soon, and other posts from people who have already ordered tham seem to suggest that they take quite a while to arrive after the order. I'll probably just order from Ben and test at the stores until it arrives. Ben put this whole sits together so ordering from him seems to be the right thing to do to support him and his efforts. I agree with you that the test results are all over th board. I think the results I got yesterday were wrong. My small home test kit agrees with the numbers I got today. My kit only does FC, pH and Alkalinity, but those numbers match. Thanks for the response.
    Doug
