It looks like a tee would be fine.
PoolDoc / Ben
Thank you. One other question i should have asked...
What advantage does having this valve offer? It allows me to stop the flow to the waterfall (which i can stop with the other valve already), or stop the flow to the rest of the system (skimmer, aerator, and in floor cleaning) - I don't know why I'd want to do the latter. It would also seem that with this current setup I could cut off all output by closing off both valves and I can't imagine that would be good.
Thank you
They may have put that valve in to force all of the water to the waterfall to get a more dynamic and active look. If you remove that valve, you won't have that flexibility anymore.
Mark
Sorry -- I over looked that. If you replace the valve with a tee, you'll have to ADD a valve to the SWCG line to be able to duplicate the control you get with the 3-way valve.
