Thread: best pool shock?
    Mar 2012
    Winchester, VA
    Default best pool shock?
    Looking to purchase my pool shock for the summer, I always get my cholrine tabs from costco since its a great deal, but looking for best bang for my buck for shock. I have a 40K gallon chlorine pool.
    Default Re: best pool shock?
    Given that you are using trichlor (tabs), which will raise CYA, you probably want to use an non-stabilized chlorine 'shock'.
    That leaves you with two choices: bleach (clorox or 'liquid chlorine') or calcium hypochlorite.
    Avoid the shock blends at all costs -- those hobo soup products are expensive, less effective, and have unpredictable effects.
  1. New pool with electrical shock
    By Jose263 in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2011, 01:01 AM
  2. Newbie: To shock or not to shock... That is the question
    By KaseyNewman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2011, 04:50 PM
  3. pool super shock
    By hoffmans in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-17-2007, 02:25 AM
  4. When do you need to shock your pool??
    By human in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2006, 12:17 AM
  5. Shock the pool
    By slowtan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-05-2006, 02:00 AM
