Thread: using Polyquat
    Mar 2012
    Ohio
    Default Re: using Polyquat
    Thanks! I found the Best Guess thread last fall. I've been running my purifier on the Nano at 25% every third night and this is keeping my FC at 7-8 ppm and 0 CC. The use of the SWCG has caused my pH to rise a bit to 7.6-7.8 and the TA is now at 100. Should a add a bit of muriatic acid? Should I consider adding borax as well to help minimize this rise every time I use the SWCG? Or should I just plan on using a the acid every so often?
    Poolhouse
    15K fiberglass inground -- SWCG Nano pilot
    Hayward 1hp super-pump -- Sta-Rite Cartridge filter-Taylor K-2006 test kit
    Using the borax will slow your pH rise, once you lower it, but won't actually change the amount of acid it takes to maintain your pH. In other words, with borax added your pool's pH may rise from, say, 7.7 to 7.8 in the time it previously rose from 7.7 to 7.9. But if so, it will take about the same acid to move the pH back to 7.7 from 7.8, that it previously took to move it from 7.9 to 7.7.
    Borax is a buffer at the high end of your pool's pH range -- and a buffer is just something that makes your water require more acid to change pH, either UP or DOWN.
    So, do as you like. You'll need to add enough borax to get your levels to 50+ ppm to see significant effects, and then add enough acid to compensate. Or, you can just buy 7 - 9 boxes of borax and 3 gallons of acid, and add the borax a couple of boxes at a time, till you get there.
    Mar 2012
    Ohio
    Thanks!
