Re: Helping neighbor with pool
Looks like my reply yesterday didn't save... weird.
So ok... today the water is much clearer, you can see the bottom in shallow and also pretty good in the transition to the deep end. The deep bottom is close I can barely make out the bottom drain.
I have continued adding Borax and even after a half of box (the second box) it still doesn't seem to be changing at all yet. I went ahead and added the rest of box 2 earlier this afternoon. Is this common to use this much Borax if the pool has not been kept up properly? Just curious.
They have been keeping the FC up high.
The filter is sand, was changed last year, capacity is 300 lbs. She knows how/when to flush but this year her gauge is dead so I'll help her replace it. The pump has been running 24/7 since I started helping them out.
-stephen
26,500g inground vinyl liner (new liner installed June 2013)
Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
Compu Pool CPSC36 SWCG - Polaris 380 cleaner
