Page 12 of 13 FirstFirst ... 2 10 11 12 13 LastLast
Results 111 to 120 of 128
Thread: adjust cya before or after shocking
  1. #111
    Kateyru is offline Subscriber Thread Analyst Kateyru 0
    Apr 2012
    Alabama
    Default Re: adjust cya before or after shocking
    No visible algae. Water looks good, nice and clear. I'll retest CYA this afternoon. Do you think I can let FC drift down or do I need to keep it at or above 15 for another day? Am really hoping for a clean pool by this weekend!
    Thanks so much!
    16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
  2. #112
    Go with another day for added insurance. If after one more day, you still don't lose more than 1ppm overnight and still have CC of 0, let it drift down. But, be diligent about keeping your chlorine levels at appropriate levels based on your CYA reading. (Like Ben said, retest CYA to make sure you know what it is so you'll know needed cl levels.)
  3. #113
    Apr 2012
    Alabama
    Okay, FC last night and this morning were the same and CC was 0. Doing insurance plan today If FC and CC are okay from tonight till tomorrow am, I'll let chlorine start the downward drift. CYA was 45 to 50 last night. I'm struggling with reading CYA and trying to accurately recognize "just till black dot disappears." I haven't had problems with chlorine levels in the past but plan to up CYA to 70 to 80 so will be more vigilant and diligent re: chlorine as needed.
    thanks again for all the help. I just read "the history" of the forum. I am so glad the forum (and troublefree pools website) exist and very, very glad I found both!
  4. #114
    Just don't ever let the chlorine get below 3 ppm, and if you up your CYA any more, then don't let it get below 5 ppm, and you shouldn't have any troubles.
    The CYA test is a very subjective test--the best you can do is try to run the test in the same conditions (lighting, distance from tube to your eye, etc) so you can be as consistent as possible.
  5. #115
    Apr 2012
    Alabama
    Glad to know it is very subjective test!
  6. #116
    It is definitely the hardest test to interpret.
  7. #117
    Apr 2012
    Alabama
    Ah, you guys, I'm back again with green algae dust ): A quick recap of most recent battle with algae...from 5/21 to 5/24, FC was over 15 until afternoon of 5/23 when it dipped to 12.5 at 2:30 pm. CYA was at 45 during this period, fyi. I think that's when (on 5/23) we thought I'd won the battle, and I was letting FC drift down. Since then, the FC was below 7 only once on 5/28 and was at 5.5 when I turned SWG back on. On 5/29, FC was 7.5 and pH was 7.6. I turned SWG back off to get FC down to 5. This morning at 10:15 am (when I noticed green algae dust), FC = 5.5, CC = 0, pH = 7.6, Ak = 80 and CYA was about 65 as I started addingCYA again on 5/29 because I thought algae was long gone.
    So, did I not keep FC over 15 long enough? How long is long enough? I think I had FC over 15 for a longer period than 5/21 to 5/23 but did not have reagent until 5/21 to know FC for sure. I know that I have to have FC at 20 now that CYA is up. Other thoughts???? Love my pool, hate the algae.
  8. #118
    Is your vinyl liner blue? If so, then I think you may have yellow/mustard algae and not green algae. Yellow+Blue(cyan) = Green. You describe the algae as "dust" which sounds more like yellow/mustard algae and would explain why the usual chlorine maintenance levels aren't keeping it away. Is the algae mostly on the wall and floor in the shady area of the pool? Yellow/mustard algae prefers shade. Do you have any removable ladders or other equipment in the pool where the algae might be hiding out inside? For plaster pools, we have people go behind light niches where they often find a lot of yellow/mustard algae if they have such an infestation, but I don't think you have pool lights (and therefore light niches) in your vinyl pool, do you? Is the algae in areas of poor water circulation?
    Also, are you sure that it's algae and not pollen?
  9. #119
    Apr 2012
    Alabama
    Yes, liner is blue. as i said on other thread, algae seems to disappear in the direct sun tho I think there is almost always a yellowish band of ??? algae (or a stain) where the wall and floor meet in several areas around the pool...if that makes sense. I have a ladder, not sure if it's removable as I've never tried to take it out. I have 1 pool light. How do I identify areas of poor water circulation? I'm fairly sure it's algae and not pollen.
    Just read section on mustard algae, and I think you're absolutely right...that's the problem! No wonder my efforts were not enough. Sounds like a major production to get rid of mustard algae.
    Many, many thanks!!!
  10. #120
    Apr 2012
    Alabama
    Just realized that I posted a response on the other thread so left out some info here. CYA was about 65 on 5/30 so my shock level is now 20, correct? I'm going with the mustard algae theory so will shock at 20 till FC loss is < 1 ppm. Hoping that is done today (I was out of town all day yesterday and couldn't do much). When that's done, I'll move to super shock to get rid of mustard algae and will keep FC at or above 35 to 40 for 24 hours, correct? I've got to figure out how to get light out of pool. Can I put robotic cleaner and cloth bag, rubber mat (float) and nylon recliner floats in pool for 1 hour (in super shock) or is it better to clean with bleach solution? Also, instructions say to wash bathing suits. Do I need to use bleach with suits?
  1. How to adjust CYA down
    By l8nite4me in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2007, 04:27 PM
  2. How to Adjust pH and TA
    By iwannapool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2007, 05:22 PM
  3. What should I adjust ?
    By aswetich in forum DPD-FAS based testing
    Last Post: 07-27-2006, 07:33 PM
  4. Adjust TA first, right?
    By jnorris in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2006, 11:07 AM
  5. Which one should I adjust first
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 01:32 PM
