Results 1 to 10 of 128
Thread: adjust cya before or after shocking
    BigDave's Avatar
    Default Re: adjust cya before or after shocking
    I would go after the algae first and then raise the CYA after you're done, it should take less bleach to get to your shock level with a lower CYA. If dichlor shock is cheap in your area, you may consider using it to start your algae battle - it will add CYA as well as chlorine. Be sure to watch your CYA and pH if you do.
    Kateyru is offline Subscriber Thread Analyst Kateyru 0
    Apr 2012
    Alabama
    Will do, thanks!
    16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
    Apr 2012
    Alabama
    Okay, I added dichlor last night. I tested ph this morning and it is way up...at least 8.2 (as high as my kit goes). I thought dichlor would lower the ph??? Should I add muriatic acid this morning?
    Thanks.
    Apr 2012
    Alabama
    at least 10, it doesn't look much darker than that
    BigDave's Avatar
    10? What are you using to measure chlorine? What kit? How much dichlor did you put in? Do you know how many gallons your pool is?
    Apr 2012
    Alabama
    I am using Leslie Basic Poolcare OTO test kit (made by Taylor). I misread, chlorine is 5 but that's the highest on the kit. I added 37 oz. of dichlor. Pool is about 22,000 gallons. thanks!
