Results 1 to 3 of 3
Thread: Need Advice
    Apr 2012
    New Jersey
    Default Need Advice
    I am thinking of having a pool and spa installed and the following was recommended as top of line:
    2 hp jandy pump
    3/4 hp polaris pump with model 380 auto cleaner
    Zodiac Fusion mineral purification system with auto chlorinator
    Aqua-Cal heat pump model 120 (113,000 btu)
    2 colorlogic led lights by Hayeard and led spa light
    Jandy pda-ps6 remote control system
    Jandy never lube 3 way valves
    Jandy 1 1/2 hp air blower for spa
    The spa is 7 ft inside diameter with 8 thermo jets
    Please advise any comments will be appreciated
    Default Re: Need Advice
    I don't think anyone here would pick Jandy's gear as their first choice, but my own experience with it is rather limited. Polaris is generally good -- even though Jandy / Zodiac owns them. I think -- but someone else may correct me -- that the 380 is one of the 'good' pressure side cleaners.
    "Mineral" systems are all useless . . . or worse. Worse is when they stain the pool and blond hair. Zodiac bought the great pool placebo, Nature2, and has marketed the heck out of it. Lots of people have them. But, they still don't do much of anything, except improve your builder's financial health.
    I'll make two more points, and then let others take it from there:
    1. Spring time is a pool builder's market; fall is a pool owner's market. But, in-ground pools ordered in spring are usually not ready till late summer, except in s. Florida.
    2. Many good pool builders are pool chemistry idiots -- don't dump a builder because he doesn't know pool chemistry, but don't trust him in that area, either.
    Apr 2012
    New Jersey
    Thanks for the quick reply. What is wrong with Jandy? What do you reccomend and why?
  1. need advice on what do to first
    By sherraechas in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-26-2012, 02:44 PM
  2. Hot tub advice
    By myatinsel in forum General Interest
    Last Post: 10-19-2011, 03:02 PM
  3. Need some advice
    By sherron100 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 08:33 PM
  4. 18' AG Advice
    By cramar in forum Above-Ground Pool Construction & Repair
    Last Post: 11-19-2010, 03:05 PM
  5. Advice please.
    By savdoc2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2006, 07:58 PM
