Results 1 to 10 of 18
Thread: Keeping Animals Safe
    Lehigh Valley, PA
    Default Re: Keeping Animals Safe
    Quote Originally Posted by veghead View Post
    We would like to remove the fence. There are safer pool covers, aren't there? If we have to, I guess we can leave off the cover completely.
    Yes, there are pool covers that will hold the weight of an elephant but you probably won't want to put that on at the end of each swim session.
    The Scamper Ramp is a nice addition to the regular pool steps, sort of an emergency exit if the dog forgets where the steps are, but neither the ramp nor the steps will do any good if the dog is under the cover and panics. My dogs are excellent swimmers. One of them followed me on the pool deck one year–I hadn't latched the gate properly–and dove into the water. The pool was covered with the solar cover at the time. He got tangled up in it and looked awfully darned scared, I'll never forget the impression on his face and the frantic splashing, trying to free himself of that huge sheet of bubble wrap. Very, very scary!
    Both gates now have a self-latching spring installed.
    I have stopped using a solar cover after my Schanuzer almost drowned! She thought it was a solid surface and jumped on it! Luckily we were by the pool when it happened and jumped in to get her out of the water. She was trapped under the cover! This was several years ago and we have not covered the pool since!
    Keep the pool fenced and the gate closed and it should never be an issue. My huskies love to swim, but we only let them in the pool area when we are there. You want the solar cover on the pool all the time when you are not using it. If it costs you $1,000 to heat it without the solar cover, it will cost you about $100 to heat if you use the cover.
    Apr 2011
    Hi,
    We have a male 2 yr old Rottie we've had since 8 weeks and he loves to swim. He doesn't like to jump in from the deck which is 3" above the pool ledge so I built him a ramp that's hinged to the deck and he loves it. He is in and out of the pool by himself all summer. He swims over to the wedding cake stairs and climbs out.
    This is an 24' above ground with a permanent deck 1/2 way around. Although I heat the pool I won't use a bubble cover for the same fear. During winter I run a 3' high piece of cyclone fence across so he can't get near it. Looks like hell but I'd be devistated if something happened to him. I realize I'm wasting money by not using the bubble cover but I also really enjoy looking at the water vs the cover.
    That's my story.
    Cooper
    Mar 2012
    Nevada
    The pool does not have a heater, but I do live in the desert southwest. I am thinking about getting a roof solar heater. Quite honestly, I think the bubble solar covers look like heck too. I know, though, they will cut down on cleaning and help with retaining heat.
    Lehigh Valley, PA
    Hi Cooper,
    I'm very interested in learning more about the hinged ramp you built. Do you have photos of it posted somewhere?
    Apr 2011
    Hi Anna,
    No I don't. But I should have one on my computer if I can figure out how to post it. I bought one of those white plastic ramps from the pool store but it wasn't big or strong enough for him. He weights 157 pounds.
    I'll look
    Cooper
    Apr 2011
    May 2012
    Winston-Salem NC
    I just read your post and wanted to cross-post to http://www.poolforum.com/pf2/showthr...de-solar-disks which we use to avoid the same trapped-person-or-pet scenario you are describing.
    Alison
    16'x40' kidney / "nautilus" 25K gal IG vinyl pool; SWCG; Hayward ProSeries high rate sand filter; Pentair SuperFlo 1HP pump; hrs; Taylor K-2006C; utility water; summer: homemade solar disks; winter: mesh; ; PF:4.8
