Re: Jandy PureLink/AquaLink RS/AquaPure Problem
Thanks for the info and tips. I'm now getting a LO chlorine production signal which is suppost to indicate a temp less than 60 when the temp (if I believe the sensor reading on the PDA) is 67. I also can't tell what is involved in getting to and replacing the front panel so I'm really considering calling in someone who has worked on one before, if I can find someone.
