Closed Thread
Results 1 to 10 of 34
Thread: spring startup
    Apr 2012
    southern Indiana
    Default Re: spring startup
    Is CC what determines if you need to shock ? And what is the normal reading if you don't need to shock? again Thanks Jerry
    Fiberglass in ground, outdoor 6500 gal; Hayward chlorine dispenser, cartridge filter, & 1 HP pump; 10 years old
    There's no absolute answer; most of the time, if it's more than the minimum reading, shocking is a good idea. But, some pools tend to run a bit more CC, and if it's not causing a problem . . . then it's not a problem. The minimum reading is 0.2 with the 0.2 ppm drop test, and 0.5 with the 0.5 ppm drop test.
    Apr 2012
    southern Indiana
    Thanks,
    Jerry
    Quote Originally Posted by jarsch View Post
    Thanks Jerry
    Jerry? Who's Jerry? As in Ben and Jerry maybe?
    Apr 2012
    southern Indiana
    No just plane old Jerry from Indiana
    BigDave's Avatar
    Sounds like a new flavor.
    Now I get it. Ben's edit made it clear. I thought you were thanking Jerry. Instead you are saying thanks from Jerry.
    Well, plain old Jerry from Indiana --- welcome to the Pool Forum! We are very glad to have you! Hope I didn't offend you. I thought perhaps Ben had decided to change his name or something! He's prone to doing funny things at times!
Closed Thread
