Results 1 to 5 of 5
Thread: Replaced pump
    Apr 2012
    Mississippi
    Default Replaced pump
    I just replaced my Hayward super pump and changed my sand in the filter. My pressure was 40 psi, I back washed and it went down to 35. I feel like this is still too high, any suggestions?
    Apr 2012
    Mississippi
    Default Re: Replaced pump
    I wanted to add that my returns are good and strong like they are supposed to be.
    mas985's Avatar
    Pleasanton, CA
    That sounds more like the gauge is broken. Does the gauge go to zero when you shut off the pump? Are you getting decent flow out of the returns?
    Mark
    Apr 2012
    Mississippi
    I would like to add that when I replaced my motor on the pump that the motors thermal cutout was shutting the motor down after about 10 seconds. The problem turned out to be the timer. Some how the voltage was dropping too low and causing the pump to shut off.
  1. No power to pump? Fuse blown. Replaced & didnt fix
    By topnotch in forum Pool Equipment & Operations
    Last Post: 06-28-2011, 12:40 AM
  2. Replies: 7
    Last Post: 04-18-2011, 10:19 PM
  3. HELP! Replaced pump and the noise is back!
    By Colbowski in forum Pool Equipment & Operations
    Last Post: 04-01-2011, 09:24 PM
  4. Just replaced my lightbulb
    By otitis in forum Pool Equipment & Operations
    Last Post: 07-22-2007, 11:18 PM
  5. CYA 230, replaced 1/2 of water...now 217???
    By CandyMoss in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2006, 07:47 PM
