Results 1 to 10 of 10
Thread: Yellow algae won't go away!
    Mar 2012
    Southern California
    Default Re: Yellow algae won't go away!
    Alright, I got a free water test from my local Leslie's over the weekend, and here's what they found.......
    calcium- 560ppm (!!!!!)
    CYA- 100ppm
    alkalinity- 90ppm
    pH- 7.4
    phosphates- 20ppb
    Obviously, I need to do some draining and re-filling to get the calcium hardness down. What else would anyone here recommend?
    The calcium is not a problem UNLESS you have scaling. In California, you'd better test your fill water, before assuming that draining and refilling will fix things.
    You *need* a K2006. But, stop-gap, check and see if you have a Walmart in your area that has this kit:
    http://www.walmart.com/ip/HTH-6-Way-Test-Kit/17043668
    This is a private label custom Taylor kit, that's compatible with the K2006 . . . and it will allow you to get a reasonable CYA level, now.
    Meanwhile, keep the chlorine HIGH (OTO => orange!), and brush. Do NOT use any more stabilized chlorine. Get your FILL water tested (or, better, get the K2006 -- here's the info page: http://www.poolforum.com/pf2/showthread.php?14994) before you think about draining.)
    Also, please post your pool info in your signature, here: http://www.poolforum.com/pf2/profile...=editsignature so we don't have to keep looking through the thread to see what sort of pool you have.
    Do NOT drain, till you've tested your fill water. Do NOT drain, if you have an AG, vinyl or fiberglass pool. Doing so incorrectly can DESTROY those pools.
    Mar 2012
    Southern California
    I got my fill water tested. Calcium came out at 80ppm.
    built 1973
    25'x50' kidney 25K gal IG concrete pool; clorine tabs; Hayward DE filter; Hayward pump; 12/14/2012hrs; 0; utility water; summer: none; winter: none; ; PF:4.8
