Thread: sand or foam?
    Default sand or foam?
    Which is better for a substrate under the pool?
    New Orleans, LA
    Default Re: sand or foam?
    If you are going to use foam, I would still use some sand. Another good option is Gladon's Perfect Pool Bottom. It is a 30 mil hard plastic sheet that goes under the pool to protect against grass, rocks, etc.
  1. wall foam
    By jeremy122 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-07-2012, 03:09 PM
  2. Oh My.. foam everywhere!
    By tamil in forum Pool Equipment & Operations
    Last Post: 05-19-2006, 11:09 PM
  3. Foam bottom with sand cove
    By scottfly in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2006, 10:04 PM
  4. Vapour liner/plastic/foam before sand cove
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 04-05-2006, 12:17 PM
