Results 1 to 9 of 9
Thread: Filter and Bleach
Threaded View
  1. #6
    Default Re: Filter and Bleach
    Are you able to add bleach both morning and evening? If so, great! Since you don't have any CYA right now, a good shock level for you would be around 10ppm. In your pool, each quart of 6% bleach will add a little over 1ppm of chlorine. So, each time you test, add enough bleach to get the chlorine back up to around 10ppm.
    What kind of test kit are you using? If you haven't already done so, order a Taylor K-2006 or 2006C from the Amazon link in either mine, Ben's or Janet's signatures.
    By the way --- no question is silly. If you don't know something, the only way to find out is to ask.
  1. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  2. Help! Switching out 1985 cart filter to sand filter
    By JLICHTY in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 11:09 AM
  3. Replies: 7
    Last Post: 05-16-2010, 09:46 AM
  4. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
  5. Baq-to-Bleach conversion w/cart filter
    By Michael23 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-17-2006, 04:22 PM
