Re: Aqualuminator leaking AG pool
Hi Sharon, I can't quite figure out where you're saying it's leaking....
by bottom outside - do you mean where your hose attaches, or where the cap goes over the wires??
If it's where the hose attaches, do you have a fitting glued on to which you clamp the hose? Any other equipment tehre like a shutoff valve? Can you try to explain how it all comnes together working back from the aqualum. and try to tell us the exact spot where it's leaking - I may have a fix.
BTW - The connection on teh aqualum. is a non standard size, I glued a proper sized fitting to mine to help with this issue.
