Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 62 of 62
Thread: Pool Opening Problems.
  1. #61
    Default Re: Pool Opening Problems.
    Please do.
  2. #62
    Jun 2011
    In the Sticks near Houston, TX
    OK, I just wanted to update this thread. My pool is sparkly clear, and all I have been using is the BBB method and keeping a close watch on the chemistry.
    It took the sand filter about 2 weeks to clear the water up once I got the FC up to the right level. I added 10 large jugs of bleach, which brought the FC up to 50+, and then within two days it was between 10-20ppm. After that it went down below 6 ppm, and the water got better every day. I am also a big believer in 2-speed pumps. I run mine on high for 2 hours in the morning and then switch to low for 10 more hours.
    Still have not installed the BW flowmeter, it's on my list.
    Thanks for all your help.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
  1. Spring Pool Opening Problems
    By JRDLEE in forum Dealing with Alkalinity and Calcium
    Last Post: 09-12-2012, 05:41 PM
  2. pool opening
    By atgvir01 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-13-2011, 09:27 AM
  3. Opening AG Pool
    By Ken S in forum Above-Ground Pool Construction & Repair
    Last Post: 01-30-2007, 10:35 PM
  4. Opening pool
    By brian87gt in forum Dealing with Algae & Slime
    Last Post: 05-28-2006, 02:28 AM
  5. Pool opening
    By GolfTop in forum Dealing with Algae & Slime
    Last Post: 04-01-2006, 10:33 AM
