Re: Pool Opening Problems.
Thanks for your info.
Here's an interesting tid-bit: The low speed amperage is right about 1.0 amp as measured with my digital amp-probe. The full speed amps are ~7 if I recall. I know for a fact that the low speed is 1.0 amps, I measured both legs because that sounded too low.
Thoughts?
~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
