Results 1 to 10 of 62
Thread: Pool Opening Problems.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pool Opening Problems.
    Quote Originally Posted by TheGoose View Post
    I'm thinking that since I have the pump restricted back and thus the flow lowered that the amps are lower.
    I don't remember you saying anything about this. How have you restricted the pump?
    Also, I noticed from the picture that you may have one of the suction lines closed. Is that the case and if so, is the 20 PSI clean filter pressure when that port is closed?
    Also, what was the model # of your original pump (e.g. WF-4 or WF-24)?
    All of these things can make a big difference in the operating point of the pump.
    Mark
    Jun 2011
    In the Sticks near Houston, TX
    The pump was restricted some by the extra DE in the filter (added per this site)....had it at about 26-28 psi. I heard that a plugged filter actually filters better. Normally I would backwash at this pressure but nothing else seems to work. I was actually running on low speed at ~10 psi, but the filter was close to needing backwashed.
    I run with the main drains closed so the skimmers will function better. I have dual main drains with the upgraded covers so it's not really a safety issue. I have a lot of over hanging trees etc. and I need as much skimming as I can get.
    The original pump is a WFE-4.
    Quote Originally Posted by mas985 View Post
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    mas985's Avatar
    Pleasanton, CA
    Ok, I think I understand. The amp measurements were made with the higher pressure but your normal pressure is 20 PSI. Correct? Also, 20 PSI is with a clean filter and one suction port closed, correct?
    But I don't believe it is possible for that pump run on low speed at 10 PSI. Max head for that pump on low speed is 22' and 10 PSI would put it well over that including gauge height. Also, if the filter was reading 27 PSI on high speed, it should have read somewhere close to 5 PSI on low speed. So either there is a problem with the pressure gauge or you did not read it correctly.
    Mark
    Jun 2011
    You're actually correct. The gauge is ranged to like 60 psi but really should only range to 30 psi for better accuracy.
    At low range it's running under 10 psi, I believe about 6 psi. When the filter is plugged and the pump is reading about 26-28 psi on high speed it doesn't really change low speed pressure as much. Low speed is still under 10 psi, I believe about 6-8 psi but I haven't looked at it real close. Now that I think about it 6 psi is probably about right.
    I was just rounding to 10 psi but it is definitely under that.
    Thanks for all your help.
    Jun 2011
    Blue White flow meter in hand. We'll know soon enough about my flow.
    Please do.
    Jun 2011
    OK, I just wanted to update this thread. My pool is sparkly clear, and all I have been using is the BBB method and keeping a close watch on the chemistry.
    It took the sand filter about 2 weeks to clear the water up once I got the FC up to the right level. I added 10 large jugs of bleach, which brought the FC up to 50+, and then within two days it was between 10-20ppm. After that it went down below 6 ppm, and the water got better every day. I am also a big believer in 2-speed pumps. I run mine on high for 2 hours in the morning and then switch to low for 10 more hours.
    Still have not installed the BW flowmeter, it's on my list.
