Results 1 to 10 of 62
Thread: Pool Opening Problems.
    Jun 2011
    In the Sticks near Houston, TX
    Default Re: Pool Opening Problems.
    Blue White flow meter in hand. We'll know soon enough about my flow.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    Please do.
    Jun 2011
    OK, I just wanted to update this thread. My pool is sparkly clear, and all I have been using is the BBB method and keeping a close watch on the chemistry.
    It took the sand filter about 2 weeks to clear the water up once I got the FC up to the right level. I added 10 large jugs of bleach, which brought the FC up to 50+, and then within two days it was between 10-20ppm. After that it went down below 6 ppm, and the water got better every day. I am also a big believer in 2-speed pumps. I run mine on high for 2 hours in the morning and then switch to low for 10 more hours.
    Still have not installed the BW flowmeter, it's on my list.
    Thanks for all your help.
