Results 1 to 8 of 8
Thread: Need advice on new pool pump
    Default Re: Need advice on new pool pump
    In case you're missing the implications in what Mark is saying, here's they are stated more plainly and less politely:
    1. Variable speed pumps haven't been around long enough to be fully tested.
    2. We don't know how the electronics stand up to thunderstorms.
    3. Serviceable parts can be VERY expensive, and we don't know what the life expectancy is.
    4. There's a lot of hype from ALL the companies about these pumps, and we haven't fully penetrated all of it, yet.
    5. In particular, the savings compared to a 2 speed pump with proven technology generally seems to be exaggerated.
    Apr 2012
    Panama City Beach, Fl
    What kind of controller would be needed? My old burned out system is a pentair.
    mas985's Avatar
    Pleasanton, CA
    If you are going with a two speed, you can get away with a two speed timer such as this: http://www.amazon.com/Intermatic-T10.../dp/B0039Q7NYI
    If you go with an Intelliflo 011018, it has a built in timer which would not require an external timer.
    Mark
    Apr 2012
    I went with the Hayward Ecostar. I think it has a built in timer, similar to the pentair. I dont know personally yet, because I have not hooked it up.
    As for the time listed in the amazon link, mine is exactly like that, but it only has one dial. It does in fact still work though.
    In Ground, 6,900 Gallon Gunite pool with tile trim, Haywayd EcoStar SP34000VSP Variable Speed, Aquarite 25k SWCG, North Florida
    I hope you'll let us know how it's worked for you, sometime this fall. Feedback from the field is very, very valuable to us.
    Apr 2012
    I will do. I am a forum junkie. Just recently game got a new house and my first pool. I will be around for a while
