Results 1 to 10 of 20
Thread: Accepting the challenge
    lstinthot is offline PF Supporter Thread Analyst lstinthot 0
    Aug 2011
    Default Re: Accepting the challenge
    Test results this morning:
    CYA - 160 using 3 parts clean water 1 part pool water mixed in separate container results were 40ppm. Looks like the rain water has lowered the CYA a good bit from a month ago.
    Ph - 7.0 to 7.2
    Adding another box of borax and should be able to start adding bleach. Looks like about 11 gallons to get up to the 30 ppm range.
    What kind of drop in Cl levels should I expect?
    Thanks,
    ~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
    The drop in Cl levels will be pretty big at first while the worst of the mess is cleared up, but you should start seeing the drop decrease as the pool clears. With a CYA that high, I can't really tell you how far it will drop, but the more consistent you are about keeping it at or above shock level, the faster the mess will be cleared up.
    Aug 2011
    Ph was high today. over 8.0. What is the general tendency for pool water Ph for a liner pool? Will we have to add acid to bring in back down regularly as we are maintaining high Cl levels?
    This is day 2 of pump running. The first picture of section was taken about a month ago, however pump was not running during this time while they found the leak or reason it would not stay running. All that was done for the first month was direct rain water from the roof to start diluting out the CYA. You can see the gutter system in the picture.
    Pool is starting to show progress, this picture was taken this morning and my wife said she was able to make out the bottom of the shallow end this evening.
    FC last night was 32
    FC this morning was 25
    Added bleach to bring back up.
    You can't test pH accurately when the chlorine is that high. You often will get a falsely high pH reading. Wait until the chlorine drops below 15ppm before trusting your pH reading.
    Aug 2011
    I took the water into work and it read 7.9 with the equipment there. They do not use drop wise testing, is it possible to affect meter equipment?
    Aug 2011
    Turning pool over to happier home owner. They were going online today to order their own test kit using the link provide on this web site. I will be a coach for them. Started showing them how easy it is to test water and talked about not putting any more stabilized shock or chlorine in the pool. The pool is making progress, still cannot see the bottom of the deepend. It has been at shock levels (25 to 35 ppm) for about a week. Vacuumed alot of sand out of the deep end today. Had home owner install a valve between pump and filter so we could slow the water down a bit. Filter is rated at 20 gpm per the side of the filter. Pump is 1 1/2 Hp pentair pump.
    Will keep posted as pool clears with pictures. Just in case others want to see a really bad pool with high CYA cleared and what we had to go through.
    Since the CYA is still high, I would do a partial drain/refill and also try to remove as much physical debris as possible from the pool. Both steps will reduce the amount of junk that chlorine and the filter need to clear out.
    Aug 2011
    We have been doing drain and refill for the last month by a 1 or 2 at a time. Using rain water and well water to replace water that has been removed. Decided we will maintain a high CYA pool until the levels drop due to splashing once the kids start swimming and keep lowering level before a storm. We have been vacuuming blindly each day. Can not see the bottom of deepend. Just vacuum until skimmer basket does not collect stuff anymore.
    We did slow down the pump flow rate with a valve on its discharge. Will vacuum up today's sand mess and see how the lower flow rate does.
    Aug 2011
    The bottom of the deep end is visable. Looks like the filter is blowing through even with the lower flow rates. This may account for the longer clean up time. It has been two weeks of high Cl levels. vacuumed today and got some leaves in the skimmer basket. Pressure really has not been climbing, so my guess is the filter may not be doing too much. For as dirty as the water has been I would have guessed we should have been backwashing at least every day or so. I was going to put some DE in the skimmer to help get the clean up moving along faster, however after I backwashed the filter, rinsed and lined back up to the pool, there were streams of sand where the jets shoot back in the water.
    Holding off on putting DE in filter until sand no longer shooting through.
