Results 1 to 10 of 14
Thread: Testing out my test kit
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Default Testing out my test kit
    So, I'm testing my tap water (well water with purification system) just to get an idea of how my kit works. I got the Taylor 2006C. I'm attempting a chllorine test - filling the tube to 10ml. Instructions say to add 2 dippers, and if chlorine is present it will turn pink. For me 2 dippers just turns the water cloudy. If I add 4 dippers it will turn a very pale pink. So, should I be adding 4 dippers for this particular test?
    When I start adding the reagents, it appears to turn clear-ish but not as clear as what I started with. Should I be getting back to as clear as what I started with?
    I don't want to waste anymore product, but I find myself adding 8-10 drops of reagents so I'm thinking something is wrong....
    Default Re: Testing out my test kit
    You don't need to add 2 dippers of powder--if one won't turn it pink, then you have no chlorine. When you add the reagents to get it clear, it won't be as clear as the sample you started with.
    Jun 2011
    In the Sticks near Houston, TX
    Why would you have chlorine in your well water? Are you using a chlorinator on your well system?
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    Aug 2011
    Massachusetts
    I actually thought the DPD powder added chlorine. Epic Fail! Maybe I should actually read the book instead if just the inside cover of the test kit.
    LOL, it helps
    Just to clarify my post above, I have had the chlorine levels in my pool up into the 30-40 ppm range for extended periods of time (don't ask!) and it only took one scoop of powder to produce pink. It is possible, and I think one of my fellow mods is actually trying this out for clarification, that extremely high chlorine levels may bleach out one scoop of powder. However, even if that's so, you shouldn't find that level of chlorine in any source of drinking water.
    Lehigh Valley, PA
    Quote Originally Posted by TheGoose View Post
    Not answering for Jacob99 but it's common for well water to be chlorinated. We have a chlorine injector that uses diluted household bleach which it injects into the line that brings the well water into the house. That chlorinated water goes into a 150 gal holding tank. When a faucet is opened, water is drawn from the holding tank through a very large carbon filter into the house lines. The chlorine in the holding tank is around 8 ppm. What I draw at the sink is 1 ppm or less.
    When I have to top off the pool I turn off the chlorination system and use straight well water. We don't have metals in the well and its alkalinity is right around 50 ppm, perfect for my pool. I usually adjust the FC to 5 ppm after a refill and let it drift back down to its normal 3 ppm.
    Didn't mean to highjack your thread, Jacob. Having a good test kit is really very useful when you're using well water.
    Aug 2011
    Massachusetts
    Quote Originally Posted by AnnaK View Post
    No worries. Pretty interesting actually. I'm not sure how mine works to be honest. All I know is that I have to dump water softening salt crystals into it every few months...
    So, should I be testing my well water for alkalinity? I'm not planning on filling my pool with it, but will probably supplement with about 5000 gallons over the course of a few days. I need almost 24000 gallons, and (3) 6500 gallon trucks will give me 19,500 gallons. I plan on topping the rest off with my well water.
    It wouldn't hurt to know what it is, but that's not a priority right now, since only about 1/5 of your total volume will be well water, and the rest water trucked in--the end result will be affected more by the trucked in water. Either way, it's an easy fix. A more important thing to know is if there is iron, copper, manganese, or any other metals in your well water--that WILL be a priority when you fill with it.
    Jun 2011
    Generally speaking, although it's pretty easy to chlorinate your well water, it's not preferable.
    Why not just fill the pool from the well? Do you have a slow producer?
    Quote Originally Posted by Jacob99 View Post
    Aug 2011
    Massachusetts
    Is calcium hardness the test for iron, copper, and manganese?
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
  1. Testing CYA
    By clayw1963 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-02-2006, 10:03 AM
  2. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  3. pH Testing
    By cheshamjim in forum DPD-FAS based testing
    Last Post: 07-11-2006, 10:31 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. pH Testing
    By bmgo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 03:33 AM
