Results 1 to 10 of 18
Thread: Pre-Filter on a Refill?
    Rottwieler Guest
    Default Pre-Filter on a Refill?
    Hey guys.
    I've been snooping around here off and on over the winter, but now I'm ready to start getting serious as the grandson has already started using the pool.
    The pool supply house says my water is full of minerals, etc. and that I need to drain the pool and re-fill.
    I have several questions about that process, but my first question is whether it is worth it to pre-filter the fill water?
    Our water here is very hard and full of all sorts of things. They actually advise against letting small children drink the stuff due to excessive amounts of fluoride.
    I need to look up the stats on the pool, but I think it's about 20k gallons - modified kidney shape with a large wading step and depths from about 4' to 7'.
    Is it OK to just pump out all of the water, scrub out the pool a bit, and start filling it back up?
    We're in the Phoenix area so we're talking very dry soil. Pool is about 5 years old.
    I'll snoop around looking for answers on my own, but the search function doesn't seem to work so point me in the right direction please.
    I also need to find your recommended test kit... I think that's in the Tips.
    Appreciate any guidance.
    Sam
    Default Re: Pre-Filter on a Refill?
    Hi Rotweiler, and welcome to the forum!
    Has the pool supply house told you what minerals are in the water? Are they something you've added, or are they in the fill water? What kind of pool finish do you have--vinyl liner, plaster, gunite, etc?
    The recommended test kit is the K-2006, and can be gotten for a very good price through the Amazon link in my sig. Try using the Google search feature linked in my sig, as well--it works much better than the v.bulletin search feature on this forum.
    Quote Originally Posted by Rottwieler View Post
    Call your water company, or check their website, and get their latest analysis. Then either post the link to the analysis, or send me a photo of it ([email protected]) or transcribe the mineral section.
    In Phoenix, I don't think you're going to have any of the high water table problems we warn people of - the only concern would be water use restrictions. But if it's OK with the water company, it should be find to do just what you say.
    One warning -- it's not good for plaster to get really hot and dry. So plan to clean quickly, and refill ASAP.
    Without seeing the analysis, it's impossible to tell if it's worthwhile . . . or even practical to pre-filter it. Most minerals can be removed with the right zeolites, but setting up a system to do that would be quite expensive. Some metals can be removed more easily, but again, without seeing what you've got, it's impossible to say.
    Rottwieler Guest
    OK. Thanks for the replies. I have been traveling for business and this got bumped back, but now I'm moving it back up to the top of my list.
    I believe the pool is plaster. There is quite a bit of dirt/discoloration around the steps that scrubbing hasn't helped. I guess we'll need to do some painting.
    Is there anything we need to be particularly careful of when cleaning the drained pool?
    I have requested a copy of the latest water analysis from the water company and have ordered the test kit. I figured I'd take a pool sample down to Leslie's and see what their analysis says and post it along with the water company report.
    When I get the test kit, would it be worthwhile to do testing on the pool water, the outside faucet water, and the softened and filtered house water, or am I going overboard?
    I'm totally new to all of this and you guys tend to speak in code that I don't understand, so thank you for your help and patience.
    Sam
    It wouldn't hurt to test all three--except you don't need to waste the CYA reagent on any of the faucet or house water, because there won't be any in there. It's nice to know what the numbers are on your fill water.
    We're here to help folks who are new at this--so don't be shy if someone posts something that you don't understand--ask, ask, ask!
    Rottwieler Guest
    Here is what I could find from my water company:
    (http://www.gwresources.com/resources...ulfer_2010.pdf)
    Substance......... MCLG or....MCL, TT or.....Lowest.....Highest.....Compliance
    ........................MRDLG......MRDL........... ..Level........Level........Achieved
    Chlorine
    [as Cl2] (ppm).... 4 ............ 4 ................. 0.2 ......... 2.6 ............ Yes
    Haloacetic Acids
    [HAA5] (ppb) .... NA .......... 60 ................ NA .......... 2.2 ............ Yes
    Total Trihalomethanes
    [TTHM’s] (ppb) . NA .......... 80 ................ NA .......... 14 ............. Yes
    Inorganic Chemicals
    Arsenic (ppb)
    2008 Data ......... 0 ............ 10 ................ NA .......... 5.0 ............ Yes
    Barium (ppm)
    2007 Data ......... 2 ............ 2 .................. NA ......... 0.18 ............ Yes
    Chromium (ppb)
    2007 Data ....... 100 ......... 100 ................ NA .......... 28 .............. Yes
    Fluoride (ppm)
    2007 Data ......... 4 ............ 4 .................. NA .......... 1.2 ............. Yes
    Nitrate (ppm)
    [Nitrogen] ........ 10 .......... 10 .................. 5.8 ......... 6.8 ............. Yes
    Selenium (ppb)
    2007 Data ....... 50 ........... 50 .................. NA .......... 3.5 ............. Yes
    Microbial Organisms
    Total Coliform .. 0 ............. 1 ................... NA ........... 0 ............... Yes
    Radionuclides
    Alpha Emitters (pCi/L)
    [2002 Data] ..... 0 ............ 15 ................... NA .......... 2.9 .............. Yes
    Lead and Copper
    Copper– less than 0.022 ppm
    Lead — less than 3.8 ppb
    Test kit should be here tomorrow.
    Not showing anything there that needs to be pre-filtered.
    Of course, if the distance from the plant is great, and the distribution is old and iron . . . that's a different matter.
    You can do the white bucket test:
    1. 5 gallon CLEAN white plastic bucket
    2. 4 gallons of tap water
    3. 1/8 cup of bleach
    4. 1/8 cup of baking soda
    5. Mix, cover, wait 24 - 48 hours
    6. If there's colored sediment on the bottom of the bucket, you might want to pre-filter
    Use Clorox bleach for this test; some cheaper bleaches might have small amounts of iron.
