Check your SWG--they frequently drive pH up.
I was planning of starting the TA lowering process without the SWG as I was under the impression with a new plaster pool the PH fluctuate in the first year a lot so I don't want to raise the PH with the SWG as well. I would monitor the CL so I can start the SWG if my CL gets out of control.
Does that sound good to you?
That brings me to a question about the process I don’t have spa jests so I would need to add water via the hose to force bubbles into the water? I was also thinking that, as I have a IG cleaning system, to release the pressure from the filter and then start the pump again which always results in a big bubble bath from the floor upwards.
Can that damage my pump or filter if I do it to many times in a row?
I just don’t know how much aerating it take s the lower the TA.
Guido
Ok I admit that was a stupid idea.
I brought my PH down to arround 7 the lowest I can see on my test kit. And I started aerating with a nozzle. I also used the power washer when I cleaned my deck. That works very good. I got my TA down to around 120 on Saturday and it went back up to 130 Sunday. My PH went back up to 7.6 so I added last night more acid and will aerate today more.
Guido
That's the way to do it. You rachet the T/A down, pH rises from aeration, then you rachet pH and T/A down again. You are on the right track. However, I would not be so drastic in aeration. Leaving your pool uncovered helps. Tossing in a half-dozen 10 year old boys will aerate very nicely. When I have to do it, I have a little sprayer that screws into my return, replacing the eyeball jet. It's about $20 and does the job beautifully.Originally Posted by Guido
I believe that you will need to add a lot of acid to your pool generally this year as the concrete/plaster cures. I don't know alot about SWGs--just some super-basic stuff. Normally, Tri-Chlor pucks are great for new concrete because they are acid, provided constant chlorine, and add needed CYA. But your CYA is almost too high.
I THINK you can use the SWG, and compensate with Muriatic Acid, but the pool guys will know better. With your PERFECT calcium levels, I'd avoid cal-hypo too. I suspect when T/A is below 125 and pH is around 7.5, your scaling will stop. But I'm speculating.
I will try to get TC at the level the best guess chart suggests at around 6 or 7 so I will be OK with my CYA and will see how the CYA will drop over the summer with backfilling and so on.
You mention a sprayer for the returns. Were can I get this type of things? I would like to have something similar as the 10 kinds from the street we live in, think the water is still to cold to swim.
Guido, Carl mentioned that your CYA level is high, but it is the level recommented for most SWG manufacurers. They also recommend being able to run a 2-4ppm CL level with that high of a CYA. I run my CYA lower then recommended, but have no issues with only a 2-3ppm CL level. The theory for this discrepency for the difference from Ben's best guess chart is the superchlorinating effects of the SWG cell. Also I'm going on the tail end of my first year with a SWG. Just keep adding acid as needed. I have to added about 1/2 a gallon twice a week to keep my PH level down in my 30000 gallon pool. Finally don't worry about the high CL level and the SWG. It will still eventually come down to the maintenance level set via the SWG. I would recommend not turning the SWG on and off, just find the correct level and leave it on.
